jerzeeog
- 102
- 4
- Apr 25, 2009
Brick City,
New Jersey
Guys I need HELP!!! Before we start with the Newbie bashing, I am not a newbie to this site (despite the account create date) nor DSM as I've had 3 eclipses but this is my first turbo (newbie to that). Also I've been searching for 3 days on my issue and have found no relevance on the forums, tech sites, vfaq or anywhere I've looked. Now that all that is out of the way this is the issue, PLEASE HELP....
I just bought my first turbo (96 GS-T, from a guy that had it parked for about 4 months) and I'm having an issue with the oil pressure. When the car turns on it idles REAL BAD and the RPMs wont pick up when gassing it...Looking at the oil pressure gauge in the car I noticed it doesnt even move at all at first....Once the engine is a bit warmer you could accelerate and once over 2k the roughness stop, the engine runs nice and the oil pressure goes up (to about half way and fluctuates as it should when accelerated)...However once the gas is released the oil pressure gauge goes down gradually and after about 10seconds the bad idle starts and the RPMs drop under 1k and the engine stalls.
Everything I have read is for the opposite of this (High idle, High pressure then low, etc...) nothing that touches on my particular issue. I read about proper oil pump priming, there no leaks, and I'm hoping to resolve this without changing the oil pump. I will be dropping the oil pan and checking on the pick up/strainer to look for gunk and clean it. And also installed a new TPS as the old one looked suspect. Any responses or suggestions will be greatly appreciated.
