InfiniteGSX
- 3,183
- 15
- Dec 10, 2002
Tijeras,
New Mexico
Ok. To start off with my story. When I did my last motor swap, which only lasted about a 100 miles, Everytime I push the clutch, it would slow the motor down, like rpm's would drop. I just put a new motor in and now when I press the clutch and hold it will kill the motor pretty quick. I have to rev it to press the clutch to keep it from dying.
However, this is new to me.... Sparks fly!!!! When I press the clutch sparks fly everywhere from under the car and it is making some kinda grinding sound when I press the clutch, I know the TOB is in there cause seriously....
If I rev it so I can press the clutch, press the clutch and try to put it into gear it will grind and pop in, so assuming I need some more bleeing. BUT that would NOT make sparks fly like that.
Would rust do this? Its a good clutch but the Flywheel, Pressure Plate and Clutch disc got a little bit of surface rust. Not full out gold, just some flakes of rust on it. Would that be the sparks and grinding sound? Is the clutch toast with the little bit of surface rust? or will it just burn off?
There's no way I could press the clutch if the TOB wasn't there....? nah.... I don't think so but my friend does. I drove it home and it was fine driving, its just when I press the clutch. It slipped into 3rd just fine and 4th just fine.
I'm gonna go to bed now cause I been up all night finishing putting it together.
BTW, even if I barely press the clutch peddle it will kill it...
i had this same problem, i was looking at the block when i swapped in another trans thinking WTH its double threaded, i even started a thread on here to find WTH was going on, it took a trip to the junk yard to realize what needed to be there, i quickly pocketed the bolt and put it in, (Whew) i thought another trans was goin out.
