- Thread starter
- #451
turbosax2
Moderator
- 4,485
- 682
- Nov 19, 2006
Mechanicsburg,
Pennsylvania
What I really want to know is how the fluid from the primary and secondary lines is split. By the look of that 3rd picture with the non-abs prop valve I'd say one line(primary) goes in and splits the fluid between left/front and right/rear and the other line(secondary) is split between right/front and left/rear.
So it looks like no matter what 2g dsm, the primary and secondary lines are to be split diagonally not front/rear from the master cylinder...
I was concerned that maybe the master cylinder was actually split f/r and then went to a diagonal channel within the hydraulic unit. I'm still not 100% sure of the system, but it's getting slightly clearer.
That is correct, it is diagonally split for safety reasons.
The non-abs info is in section 35A of the FSM. MB895931 is the prop valve you will need, but I'm not sure if the dealer still sells that or any of the lines. ABS cars use a 4 port prop valve and non-abs cars use a 6 port prop valve.
This is the best picture in the FSM I could find of the system. It's a little sketchy, but you can see how the lines travel in the non-abs system.
Before I started, I documented where every wire is supposed to go so I should be good. When I finished the ecu harness I went through and checked every single wire that I touched with a multimeter to make sure the wire went wherever it was supposed to, no problems there. When I finish the fuse box harness I'll do the same thing, and then check the wires that span between the 2 harnesses. I'll check all the systems like headlights, taillights, horn etc. before I fire up the car so that will verify the wires on the fuse box harness. I'm also going to use DSMlink to check everything I can to make sure the ecu wires are right, things like coolant temp, iat, voltage, fuel pump, fans, etc.
On a plus note, I weighed the bag of wires I've removed from the car so far - 7lbs.! But from what I've heard from others the dash harness can be a little more difficult because, like you said, messing with a wire can mess with other systems too. In my case I mostly just removed the wire completely. There were maybe a few cases where I had to consult the FSM just to make sure it wouldn't cause any issues.
That car looks like it just came from the factory!!
), new tie rods on, p/s on, intake on, intercooler and pipes on, transfer case on, battery relocation 99% done, brakes are 75% done.
