264/272 Delta cams 0-60 run video inside.
Well the g-tech is most likely not accurate but it does give me an idea if its running better. The cams was my stock ones i sent in and had reground. It cost me around 190 dollars tax and plus shipping so around 213.00 or so.
Heres is a video of it at the track this weekend. This is with a e-bay 16g turbo still holding on.
<embed width="600" height="361" type="application/x-shockwave-flash" allowFullscreen="true" allowNetworking="all" wmode="transparent" src="http://static.photobucket.com/player.swf?file=http://vid41.photobucket.com/albums/e295/Jameschanley/SANY0078.flv">
just started doing research on the delta cams (i wana run 264i/272e) and pretty much have the same set up as you except im a 2g.
how are those cams holding up?
and on the video what was your time? couldnt really tell.
Time was a 7.92 at 86.65 mph. This was on 19 psi if i turned it up any higher it would hit fuel cut. But i now have a tuned eprom with that removed. I also added a water alky meth kit from cooling mist.
    • 92AWDHX40
    • eclipsemf
