3g upper/lower control arms??
Yup, here's a part list and part numbers for the rear LCA's and sway bar set-up
Rear sway bar / MR369694 / $44.56 each / Qty required, 1
Rear sway bar end link / MR333762 / $14.78 each / Qty required, 2
Rear sway bar end link nut / MB288653 / $0.94 each / Qty required, 4
Rear sway bar bushing / MR272717 / $2.95 each / Qty required, 2
Rear sway bar bushing bracket / MR369748 / $1.36 each / Qty required, 2
Rear sway bar bushing bracket bolt / MF241281 / $0.94 each / Qty required, 4
Lower control arm left / MR369664 / $30.71 each / Qty required, 1
Lower control arm right / MR369665 / $30.71 each / Qty required, 1
There are different sway bar part numbers for the 2.4 and 3.0. The ones above are the 3.0, they should have came with a larger rear bar.
And UCA part numbers...
Upper control arm left MR369955
Upper control arm right MR369956
Rear spindals are the same as well, same part number.
These are GreenGoblin's pictures of the parts on his car. Hope it's ok with him that I post them...
And a How-To on Mitsu-Media
3g rear sway bar in 2g RS, GS and GST only/no GSX/ - Mitsu-Media
What kind of updates are you looking for? I ordered all the parts for the rear sway bar new, but they won't be here until Wednesday.
And just a little FYI, suspension techniques sells a 22mm sway bar for the 3g for $150 which include new bushings. So we have a 22mm rear sway bar option now. The RMDSM rear sway bar for the AWD is only 20mm.
Received everything today.
Pics:
Pictures of the stock rear sway, which is significantly smaller (my car has sat for a while, mind the cob webs):
Old:
Sway bars: 3G (18mm) vs 2G FWD (13mm)
Control arms: 3G vs 2G
New:
Looks good. How much did the toe arms cost you. Col you point me to who made them. I'd like a set.
Did you face the two thread tabs on the arm facing up or down?
I paid roughly $175 for both. I haven't talked to the guy in years who made them, and I don't think he makes them anymore. I can disassemble one and take pictures of all the pieces if you would like? The car is still in the air.
I faced the tabs upwards, with the end link mount facing the rear of the car. The 3G bar is shorter than the 2G bar once it "turns" to the front.
Just to add to this, I did have a "little" issue with the install.
The bolt spacing on the 3G brackets is farther apart than on the 2G. Here's a picture, the bottom holes (which you cannot see) are lined up. 2G in the background, 3G foreground:
I had to elongate both holes inward to match. 5 minutes worth of work.
Now they fit perfect.
Could you not use the 2g bracket with the 3g bushing?
I'm guessing not.
That's ok. I pretty much know how to build them. I was just hoping I could by a set and save myself some time. I'm lazy some times. :p
Yea, I tried the 2G bracket first but the bushings is to big. I was hoping two bushing were the same size, just the sway bar hole was larger on the 3G. Nope, haha.
I know what you mean, trust me. Just wish there was someone close that could make all the stuff I need made. I've read through your thread on MM about 3 times. You're a pretty innovative person. I just wish someone sold the front lateral arms with the bearings in them, that would great.
So with the 3g sway bar you have to have it connect under the control arm? You can't install it over the control arm like the 2g one?
No, I tried that first with the stock control arms to see if it would work. There was no way about it.
Do you know how high it is off the ground with the 3g swaybar or not yet?
No, not yet. I'll know when I put the car down on the ground today.
Edit
The bottom of the bar sits ~3.5 inches from the ground
Heres a picture of the ride height also just for reference:
And the rear tires are bald also.
With the stock bar its the control arm thats the low point.
You can still use the 3G control arms with a stock/aftermarket 2G sway bar. You just have to orientate them differently.
