4g63turbo84
- 614
- 0
- Dec 10, 2008
ocala,
Florida
has anyone heard of using 3g upper/lower control arms on there 2g???
Note: This feature currently requires accessing the site using the built-in Safari browser.
is there any benefit to this swap??? besides the sway bar.
Looks good. How much did the toe arms cost you. Col you point me to who made them. I'd like a set.
Did you face the two thread tabs on the arm facing up or down?
Could you not use the 2g bracket with the 3g bushing?
I'm guessing not.
That's ok. I pretty much know how to build them. I was just hoping I could by a set and save myself some time. I'm lazy some times.
So with the 3g sway bar you have to have it connect under the control arm? You can't install it over the control arm like the 2g one?
Do you know how high it is off the ground with the 3g swaybar or not yet?
