96mitsugsx
- 199
- 1
- Jun 1, 2007
Mission Viejo,
California
Hi guys! Just need advice on an engine swap I did on my 97 gst auto. The car threw a rod and made a hole on the block. I found a brand new 7 bolt short block that is already assembled. It even had a box with the Mitsubishi part number on it. I used the old head but I had the machine shop rebuild it. I already put everything back together in the car and before I was about to fire it up, I decided to double check the timing. I can't rotate the crank no matter how hard I try. It was rotating before when I put the timing belt and the transmission. It was also fine when the engine and tranny was out of the car. Please help. I'm totally lost! Thanks in advance.
Hopefully, it's something easy.
