The two adjustment type cables are from a 90 and super early 91. Everything else has the single adjustment type. The adjustment is used with the cable to your left when sitting in the car. If you have the two adjustment type shifter assy in the cabin you need to swap it out for a 91.4-94 piece with the single adjustment. You may also need to swap the cable to tranny mount for the single adjustment cable as well. you can put the double adjust in your mount but the spacing between the cables is wrong making the shift geometry wrong. This only needs to be taken into account when swapping 91-94 tranny. onto a 90 model. or vice versa. You will have to check the tenth digit on the tranny to verify the year. There is a guide on here for that.
