2.6 Stroker??
c_riggan
61
Jul 24, 2008
Surprise, Arizona
Actually not really :nono:. He'll have great torque from low rpm and up, he just needs to get some nice 280 :thumb: cams and a nice turbo to go with it I say a gt35r :hellyeah:
and better be going on a awd with a SHep tranny
Honestly I wouldn't do it because you'll have to make your power in low RPMs... a 2.6L stroker would not be good for revving above 7000 RPM (IMO)
I have a GT37R with a .62 hot .76 cold. My power band is from about 3400rpm to 6500rpm. That matched with my Jacks transmission. you will get great pulls in 2nd - 4th on the stock trans. but I dont think the trans will last too long over 400 hp. Mine held 582 for a few dyno pulls then 3 got stripped
Just think about motors in general.
<b>All daily drivers want MORE torque. Stroker motors make more torque, and spool turbos faster</b>
... more torque... turning force.. = faster/easier revs = quicker/stronger turbo spool. Think of a stroker motor like this, when you have a stuck bolt and use a wrench, and you use a "cheater bar", know how easy it is to break the bolt loose? You had more leverage/force on the bolt. Same with a stroker motor, the rods journals on the crank are "farther apart" hence more force. :thumb:
Torque and Power
Myth #5 For an equal displacement, torque should be the same on short vs. long stroke engines.
Not all DD's want insta torque, especially FWD ones. My van has a 2.5 FWD with a pathetic cylinder head and it becomes difficult to drive at 15psi, in the wet you have to be extra careful. A DOHC DSM engine with that much displacement will make unusable power down low. "You'll fry your tires off kid"
Well, the plans have changed a little bit... Not going to be dropping it in the current vehicle. I will continue to build the engine (with GT35R and either 280s or 288s, BC of course). It will not be dropped in anything until I can find a nice GSX platform to drop it in, or a Spyder and a GSX doner for the drive trane. Until then, I have a come accross a late 80s Supra with a 7MGTE (for 600 bucks) that I will be DDing once I grab it.
With that said, my power goal has gone up from 400 to 600 though (and a shep trans to go with it, dont count on seeing it for a couple years though, slow build)
This was given to me when I was asking questions about internal weights and redlines:
http://www.kidzuku.com/StrokeOrNot.pdf
In the end I want to go with a 2.0 because of increased reliability and less rod angle. Less rod angle means less sidewalling and less piston rub. Just my personal opinion derived from this pdf. Read it and develop your own. :thumb:
Thanks to TunaTalon for the link.
