How do you check crankshaft end play?
The easiest way is to use feeler gauges.
GENTLY pry the crank all the way toward the front (pulley side) of the block. Slip feeler gauges between the crank and front face of the thrust bearing to figure out the clearance.
The correct and most accurate way to do this is with a dial indicator. Put the car on a lift, remove the flywheel cover, attach the dial indicator to the engine or transmission, place the plunger of the indicator against the flywheel, gently push the crank toward the transmisson with a prybar, zero the indicator, push the crank back the other way, take your reading.
Sorry about the long sentence.
Ps. Why are we suddenly all answering a five year old question?
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
