View Single Post
Old 10-30-2008, 10:08 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
delta448 Online
Proven Member
Car: 94 SHO
Tech Posts: 1,250
Classifieds Rating: 0
Reputation: delta448 is an experienced, knowledgeable member worth listening todelta448 is an experienced, knowledgeable member worth listening todelta448 is an experienced, knowledgeable member worth listening todelta448 is an experienced, knowledgeable member worth listening to
The pistons will be a custom order. Just ask that they use the stroker piston's pin location with whatever the finished bore size will be in your block. There are a couple manufacturers making 156mm rods, but you should be able to track down someone who can come up with exactly what you want without too much difficulty. However, you won't be just visiting a website and clicking your way to your engine parts with this setup. Pauter makes some of the best rods available and actually encourages custom orders:
Quote:
Originally Posted by Pauter.com
Our usual policy as to in-stock and custom built rods is a bit different from other manufacturers. We gear our production towards the custom, made-to-order end of the spectrum, stocking only a few "popular" sizes.
Cometic 4G64 MLS HG
Felpro Permatorque MLS HG
Quote:
Originally Posted by SlowBoyRacing.com
SBR Stocks 86mm Bore 4G63 Cometic HP's which is good for up to a .040 over bore. If you need a bigger model or your building a 4G64 block let us know and it's only a special order away!
____________________________
Zack H.
R.I.P. '97 TSi AWD
