Whoever you decide to get the pistons and rods from, you should call them both up and see how much more it'd be for you to use the 2.3 stroker piston in a 4g64 bore size and get a 156mm rod length. The extra deck height allowing room for longer rods is the whole point of using a 64 block over a 63 block.
____________________________
Zack H.
R.I.P. '97 TSi AWD
