60-1 with stage 5 turbine?
fwdeclipse
809
4
Dec 17, 2005
salt lake city, Utah
Does anyone have any experience with the stage5 turbine in the bolt on housing. I can get a good deal on either the stage3 or 5 wheel but if i go with the stage 5 wheel have to get a different turbine housing to put on it. I was set on the stage 3 wheel but now not sure. I know the fp red is a 60-1 with a td06h is the stage 3 smaller than the td06h?
If I had the resources and option, I would get the Stage V (T350) wheel on that compressor (yes, you'd need a new turbine housing) :) I couldn't see any gains of going from a red to a standard 60-1.
I cannot cite any facts the stage vs stage iii except this, DO NOT purchase a Turbonetics 60-1. They have the worst CHRA rating and that my friend I can cite. My turbo shafts snapped while only pushing it to 22 psi.
Well I dont have an fp red just comparing the two. I can get a brand new 60-1 center section with the stage 3 wheel for 375. For 35 more I can get the stage 5 wheel but I would need a different turbine housing cause mine is for the stage3. BTW this is a garrett center section and wheels.
I'd opt for the larger wheel. PM sent about a housing.
Again its not turbonetics so everyone can stop posting dont buy it. Looking to see if anyone has experience with the stage5 wheel over the stage3.
Well.... I guess people will always remember in the back of their minds that AGP RS60 and RS49 designed their bolt-on housing like garbage w/ the Turbonetics core turbo sucked a$$.
Well, the scary part is some of these lack-luster CHRA's are still being produced and sold as new (I wont say which vendor, though). So, it's kind of the same epidemic in a different form. Anyway, OP, goodluck with your decision. :thumb:
I agree with the stage 5 wheel. I was going to get a 60-1 pte turbo and I talked to someone about it. He said if I get one get the stage 5 wheel. He said it had a lot more top end and the spool difference was not even noticable.
I've had experience.. Stage V spools slower with more topend. Stage 3 spools faster with less top end.. Either way i hope this isn't a PTE turbo, which i bet it is since they are the only ones that really use the stage V 60-1. I hate precision turbo's, i've never had good luck..
-Ryan
60-1 Garrett T31 stage 3 wheel .82 housing
-Ryan
Well then your bet would be wrong.......
Yeah the turbo is a garrett center section with garrett wheels and I will be using a PTE turbine section and Garett compressor cover. Thanks for the help guys. BTW think I would have full boost (30) around 5k or past that?
Not to be a dick bro but you have not said anything legit to this thread so please dont post anymore unless you have some usefull info. This car is not my dd and I run e85 and have my tuning under control. Now if someone has some actual experience with this turbo please chime in. I have some locals running scm6152 getting 30psi by 5k on his stock compression 6bolt with 272s.
    • eclipsemf
