Grescht
- 166
- Apr 1, 2008
New Kent,
Virginia
ok, so i bought this car awhile back. I've done a few boost leak tests from the turbo inlet and air leaks into the CC. so i figure maybe turbo seals, or the car is cold and there is no oil pressure. still boosts fine though. anyway..... moved the BLT to the Licp. No leaks except through the oil cap. Ive done my fair share of searching and figured that my pcv hose isn't connected to anything. i've read that you have to hook it up into the intake but where. and obviously this was done for a purpose, because there is no leak in the intake mani anywhere. So what this forum is pointing to is valve seals. but it's a newly rebuilt motor with a 7-bolt head. soooooo. The reason i started the BLT's in the first place is because sometimes on warm starts it will stutter until i rev it up for a few. then it stops. and the other reason is that once i'm done running a little hard and i let the rpms drop back to idle, it will almost cut off and then pickup and stutter until i rev it. Any ideas? i'm going to do a compression test tonight. Thanks alot. and if i missed something on the search point me the right way.
whoops
