Small 16g limits
Slightly different setup to you guys as I have an Evo 1, but with the small 16G, meth injection, 264 Comp Cams and a few more little extras I was running a 12.22 1/4 mile.
I believe hes FWD though. ( Perhaps the time was on slicks?)
He didnt post much info about the pass, like what the 1/8 et or trap was, or what the 60ft was?
Is that in reference to me (not too sure)? If so then let me give you a few more details. I was on street radials and on a pretty poor road surface (Okinawa's roads being coral-based don't help one bit with traction). I do have AWD though. My ET was 114kph and the 1/8 was 7.88s (not great at all). 60ft times I can't tell you because I'm going by figures on my Rev/Speed meter. Okinawa has no set up drag strip to measure 1/4 mile times so this is all I've got. And we've no 4WD dyno to measure power either!
I raced a turbo escort wagon once.ROFL
Yeah...not that fast though.
No I was talking about the OP
Good times on my FWD I hit a 12.1 @ 114 with an Evo 3 16G. This was at 4700ft up to. Its all in the first half of the track. Get those 60' times down and bang gears like no other. Did you ever race the guy in the escort or what?
With that MPH you should be able to get that into the low 12's as is. But you could always add a 50 dry shot that will make up in case he starts catchin you.
OP, get some weight out of that thing, it will make a big difference depending how far you want to go.
You can do sleeper weight reduction stuff that noone would be able to spot you did.
If your interested I can give you some ideas!!
I would be interested in what you have to say.
Dispite the nuances and headaches, having dsm has it's luxuries :) .
Power on tap?
Gangsta looks?
Ability to hold 450-500hp on stock block?
Frequent clutch inspections due to dropping the trans twice a year?
Never having to be the DD due to the lack of a back seat?
Girls love the power bulge?
Black_Bullet -OP, get some weight out of that thing, it will make a big difference depending how far you want to go.
I would be interested in some of those ideas,I also just picked up a true Evo 3 16g off of a local, who sold it for only $120, there is no shaft play, it is in great condition, wonder what bolting this on and a new tune will do?
There is no secrets I was just going to tell him what I did as far as weight reduction; im not saying im ahead of the curve or anything LOL I just didnt want to clutter the thread....
I like clutter!!! Do tell...
Black_Bullet's List
Some really nice ideas
No front bumper crash beam, some metal chopped out frnt
no windshield washer bottle, lines
removed various brackets bolts not needed
no A/C condensor or evaporator or lines
no charcoal canister or egr or anything emissions related
no sound deadner thru out the entire car
fire wall heat padding removed on bothsides
no battery tray/ battery relocated to hatch
thick padding stripped off the underside of the carpet
no back seats or back seat belts
thin metal chopped out from under interior panels
no spare jack/ or spare tire ( i have AAA)
all gas tank and exhaust heatshields removed
light weight rx 7rims ( 11lbs a piece vs stock rims 20lbs)
light wt racing steering wheel
bottom of driveside dash removed ( under steering wheel)
2 of the metal brackets that hold the dash up ( not needed)
converted to manual seat belts instead of electric
no rear windshield washer/ motor or resourvior
light wt act 12lbs flywheel
complete abs system removed
fp race mani ( lighter than stock oem exhaust mani.)
yea so that about 350lbs worth of weight reduction believe it or not... Theres a vfaq parts weigh section soemwere online that tells you how much each piece you take off weighs...
    • 92AWDHX40
    • eclipsemf
