View Single Post
Old 08-06-2008, 08:43 AM   #161 (permalink)
Slippi84
Proven Member
Slippi84's Avatar
Region: Tri State
Classifieds Rating: (7)
Reputation: Slippi84 is pretty helpful and trustworthy
Quote:
Originally Posted by TalonESIT View Post
I can see one fabricating a downpipe for this setup, but I doubt there will be a lot more of these right away unless everyone removes their AC systems. Slippi won't need AC so he is in the clear... I've been studying the pictures pretty close and (although I know you will fix the issue) there is no clearance for your intake unless you run an open turbo or custom intake of course. There seems to be no chance if you're running AC though.
Whatsize turbo you run or want to run will dictate what you can and can't do pretty much. Like I kinda got stuck because the holset's have a type of exhaust housing style where when I mounted it, it actually put it too close to the starter. A simple spacer bewteen the turbo and manifold pushed it away enough though and I have a heat shield for the starter which I would recommend with this manifold no matter what. I can have my dump from my wastegate plumb rght back into mymain exhaust at a favorable angle and like he said I won't have to heat up the intake air befor it's even been compressed. As for a intake I had planned on using just a filter on the turbo anyway like you see. I didn't get a chance to see if I have room now after the spacer but before the spacer def not intake friendly mainly because of powersteering though. If I take out powersteering I would have a cool intake that I would probably put by the fender opening for a cold air type get up. That's all for now more updates to come
Offline
Sponsored Links
