Need new rear axle, how can i tell if it is locking or non locking rear diff ?
ShadeTreeDSM
269
Sep 16, 2005
Fort Lauderdale, Florida
ive had one axle in it before but forgot if it was locking or not. its a 1990 GSX, 3 bolt rear end. how can i tell if it is locking or non locking ? im getting a used axle and they need to know which one it is.
quick help will be appreciated.
thanks :thumb:
We don't have any locking diffs unless they are broken.
Your trying to find out if your rear diff have a viscous coupler. Viscous coupling unit - Wikipedia, the free encyclopedia
The factory test is to jack the rear end up, disconnect the drive shaft, and turn one wheel. If the other wheel turn in the same direction you have a functioning rear LSD, If it turn the other direction you either don't have it or it's blown.
