Quote:
Originally Posted by Slippi84
I did this whole thread is kinda irrelevant now but I was just respondin since someone posted in here. I have high compression that's why it's not 100% true because this engine and high boost will never meet. WIth meth I might be able to get 20psi with whose tuning the car. 2psi on my h40 should net me the power i'm looking for. To be honest I think people get caught up in power to much anyway. I want wide powerband no boost fall off and traction that the average awd guy has. I haveso much weight reduction and plans for even more that I will do what people with plenty more hp do.
Quote:
Originally Posted by 99gst_racer
Because pump gas has it's limits. So does the truth behind Dave's tech advice.
My fault for not clarifying! Don't get confused.
I'm not saying that you need to go high boost Slippi. My thinking is that since you have high compression I would apply the bigger intercooler,bigger turbine/turbine wheel, modest boost level idea ,because the car would be easier to tune. I was only posting verbatum what Dave mentions in turbo magazine which would obviously apply to a lower compression motor as far as high boost is concerned.
I think,
low compression+high boost and proper sized intercooler means easy to tune
Just as
high compression +lowboost and proper sized parts just like in the low boost example(big) ,means easy to tune.
