Here is my log BAD or GOOD?
Will an exhaust leak on the o2 house were the down pipe connects cause my wastegate not open right?
It shouldnt since the w.g flapper door on an internal w.g. setup opens by the pressure bypassed thru your mbc after set boost is reached, that pressure goes into your w.g. actuator which pushes actuators spring up in turn which then pushes the flapper door up. That wasnt the greatest explaination of whats happening but basically it shouldnt have nothing to do with a minor exhaust leak in my opinion...
Well the problem lied on a bad vacuum lines..I fixed the wastegate and hooked the mbc back up.I'm currently running 22psi and I did a pull and was getting 8 counts of knock at 1683 rpms not sure what gear but this is ok right?>Also when I step on the gas it seems to have a slight hesitation at first what could this be.Its been like that since I bought it.
22psi on a stock side mount, or you have a fmic, your pic shows a fmic but i thought earlier you mentioned it was smic?
Anyways 8 counts isnt a problem, but at 1683rpms your not even in boost yet, and normally your log should start from about 3k up, anything under there could be phantom knock anyways.
Why not just take everyones advice and turn down the boost? Start tuning there and slowly turn up the boost. I mean i would love to run 22psi but at those levels if something messes up its alot more likely to mess something up rather than being at low levels and something messing up.
I think he couldnt turn his boost down due to boost creep issues.
If his log only showed 8 counts of knock he's actually ok, especially being what rpm he mentioned.
Op post a log so I can see everything myself.
It sounds like you are on the right path to fixing the majority of your problems. If you do, however, have a leak at the 02/downpipe connection, this can cause issues with boost control and finicky out of boost performance. I know this from personal experience.
Ok . Did not fix the exhaust leak I am just waiting for the turbo and fmic. My boost seems to be holding around 17 but I am jumping 23 maybe 24 my boost is very inconsistent. When I first start to boost however when I'm hitting that much boost and I'm not getting any knock at all. But this is real weird when I'm in third when I start to boost I'm reaching like 14-17 counts of knock and I'm barely in boost or throttle. Is this ok?
Edit--Should I control my boost levels depending on knock(until I buy a wideband)?
Do this. Do a pull in third gear at wot from about 2.5k to 6k and log it. Post up the results. It's normal for a car to show knock while going through the gears but I'd keep the boost turned down. Did you check the wires and plugs yet?
I logged today and was only getting 8 counts of knock in a 3rd gear pull. I changed plugs because I used the sea foam to clean it out. It has the ngk bp6 in it now and that is what was in it.The wires are stock but in good shape.
The seafoam should help, and you want the ngk br7es not the bp6es.
Some of your knock may be phantom but keep working at it not to assume.
Well I turned the boost down to 10 pounds today and thats were im going to keep it. Until I buy the bigger turbo.
Hey man, guys have given you the answer multiple times, take their advice and study. Furthermore, DSMLINK is your best friend. It's a key to having a good tuned DD. SAFC is fine for what it is, but the LINK is the best way to go, but it's a little pricey. Try getting an AFPR and see if that helps your boost problem. If you don't fix this very soon, your next thread will read, "HELP I BLEW MY MOTOR." Hope you figure this out soon. Goodluck
:dsm:
Well I'm not really have any trouble anymore.I would love to go spend close to a grand for dsmlink and a laptop but its not in the cards right now. I just got laid off and am looking for new employment but I'm not having any luck yet. How will a afpr help my boost trouble? I just found a b16g and when its torn off I'm going to port everything to help boost problems.
Ok..Got the b16g with td05...I need a fmic but don't have the money and I'm going to install the 16g now should I boost accordingly to knock I want to run around 15 psi and do I keep the correction at -18%?
Becareful the 16g will likely creep worse.
I recommend you fully port everything, and enlarge the wastegate hole
in the o2 housing as much as physically possible. Holding 15psi without creep is
completely do able with proper porting. The FMIC would be a nice next mod.
Running the BR7ES plugs over your current plugs would also help some amongst other things. Your knock counts are fine actually, but still, id try to get it to remain under 5 counts just for your current setup until you can get your fmic and know your not heatsoaking and getting worse knock counts with every pull; especially on those hot days.
    • 92AWDHX40
    • eclipsemf
