View Single Post
Old 05-15-2008, 10:43 PM   #11 (permalink)
PieEyedPiper
Proven Member
PieEyedPiper's Avatar
Region: NorCal
Classifieds Rating: (1)
Reputation: PieEyedPiper is pretty helpful and trustworthyPieEyedPiper is pretty helpful and trustworthy
Quote:
Originally Posted by 50trimmed1g View Post
Thanks to you all. I am going to try to isolate the problem. I forgot to mention that the car will make the same noise even if I wiggle the curved arm that goes verticle to the hub area. But only if I wiggle it left and right. Does this also indicate outer tre. Should I just take off the outer tie rod end and wiggle the shaft again and see if there is still play in the inner tie rod.
That sounds to me, if I'm understanding your correctly, like that would indicate a problem with the balljoint in your upper control arm. But then again, maybe you're just loading the suspension assembly enough from wiggling at that point to have your tie rods make noise - though my tie rods never made sound, unless you count the slight click they would make when I yanked on them, indicating some wear.
____________________________
CB
'98 GSX
Offline
[posts] [gallery] [blogs] Reply With Quote
