if your 02 was/is throwing a code you should replace it anyways, and i beleive the wire for the o2 gauge is on the passenger side kick panel behind some other wires and already has a female connector on it, so you just have to run the wire from the gauge to this wire. also i don't think the gauge does anything at idle, i'm not sure if you took it out and drove it around or not, but at idle you probably won't see the gauge move at all anyways.
