Leakdown testing
I'd hold off on installing the turbo and FMIC until you figure out what the problem is. You may introduce additional problems installing them which would just complicate the process of fixing the current problem. Usually, a shot turbo will leak oil predominantly under boost.
And the blue-white smoke is definitely coming from the exhaust, not from the engine bay?
