Quote:
Originally Posted by ceedawg
The thing I don't like about the test is that the setups are completely different,however the #'s look good but are very peaky and laggy on the 2.3L setup.
He should put an entire TS setup on the 2.3L and see what he gets.
Don't like the comparison at all if I'm comparing both turbo setups. Too many variables.
Yes, I don't think he really was doing this to compare the 2 turbine housings though. I think he just wanted to show the range of possibilities with this turbo.
The 2 liter with .55a/r housing, 22psi, 93 octane no meth, that is the one I really like.
When you compare this at different rpm points to a 50 trim under similar conditions, the S256 looks pretty good. I know, you can find a wide range of 50 trim dyno results, but here's a pretty good one that I like to use for comparison purposes:
Automoto Sports Copyright© AMS 2006
At the bottom of this page, one of the dyno charts is for a 2 liter with the good AMS bolt-ons, with 50 trim tested at 21psi 93 oct, and 27 psi 104 octane.
Pure-Tuning's results at 22psi 93 oct look quite a bit better than the AMS 50 at 21 psi 93 oct, and almost as good as the AMS 50 at 27 psi 104 oct. The AMS was on a Dynojet besides, so I'm thinking the .55 a/r S256 looks mighty good compared to the ball bearing 50 trim Garrett.
Gary
