View Single Post
Old 03-01-2008, 10:02 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #27 (permalink)
Epic904 Offline
Proven Member
Tech Posts: 73
Classifieds Rating: 0
Reputation: Epic904 is more helpful than not
Quote:
Originally Posted by Streetsweeper21 View Post
My vaccum use to be 18 when i was stock after I upgraded the turbo a long time ago always stayed around 10. My oil pressure gauge was goin really high now going low when I dont rev it after a while, also my coolant temp was going crazy now it seems normal. My alternator did touch the frame when I didnt uplug the batterty and caused a huge spark you think the ecu could be damaged?
So it all happened after the turbo install. Basically 10 in/hg means your idle has to be real pour in either a boost leak or even not firing on all cylenders. The oil pressure problem could be something as simple as a bad sending unit, a bad ground, but where do the new turbo draw it's oil from? If you did ground out the postive cable i would check some of the fuses under the hood before pulling out the ecu. The vacuum leak could be the throttle seals as these are 18 year old cars. Also check to make sure the vacuum line to the gauge is good and not leaking. As for the coolant temp. guage going crazy what do you mean by that?
