View Single Post
Old 02-03-2008, 09:13 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
turboglenn Offline
Proven Member
turboglenn's Avatar
Tech Posts: 2,840
Classifieds Rating: 4
Reputation: turboglenn is extremely helpful and trustworthyturboglenn is extremely helpful and trustworthyturboglenn is extremely helpful and trustworthy
Just use blue winter mix windshield washer fluid, it's not as perfect as mixing your own methanol and water, but it's dummy proof. I have no clue on the type of tune that you're running, but if you're pushing high boost, lean AFR's or high timing, DON'T let that bottle get empty, if the car"needs" the methanol/water mix for the tune it could be very dangerous to drive without i. But it sounds like the guy just added to have it on there if he didn't give you any special instructions on the fuel needs of the car or how extreme or safe the tune is.
You might want to call and ask if it's safe without it, or if it has to run to keep the car alive on whatever tuning ( if any ) was performed on the car after it was added.
I just put a devilsown kit on my car and the "blue juice" is a deal at 1-2 bucks a gallon, and as i said before, you can't go wrong using it.
U;timately i will mix my own or just order a case at a time from devilsown, but i'll probably jsut mix it if i can find pure methanol for a good price near here.
Visit turboglenn's homepage!
