VisionPaintball
- 372
- 23
- Feb 24, 2005
Keyport,
New Jersey
Great job Tom.
When you are done you can get mine running!
Not much has changed - moly based lubes are still the best.I prefer moly-filled assembly lubes, but I've not gotten into engine guts this century.
I got it from NABR a while back.Not much has changed - moly based lubes are still the best.
Your progress looks great, Tom. Keep up the good work.
I think one of the Link guys borrowed that "Rely-on-ability" line from my profile here though.I got it from NABR a while back.
I ended up getting really mad and just using an adjust lock-wrench (brain fart on what it's called right now).
Here's a curious question, does anyone know the answer to this? What's up with the drilled/cut/welded crank
Evidence of being balanced. Remove material here, add material there. The rotating assembly of any internally balanced engine should show signs of being balanced.
Beautiful build so far Tom. Powdercoated parts are definitely a plus. I'm curious though. Why did you go external? Better boost control?
Gives me hope and courage to do my own build here soon!! Keep up the good work man and love the color scheme you got going on. Looks sharp!
