View Single Post
Old 12-21-2007, 10:41 PM   #46 (permalink)
blcknspo0ln
DSM Wiseman
blcknspo0ln's Avatar
Region: Tri State
Classifieds Rating: (4)
Continuing on... I found a barbed 1/4"fitting for the water feed for my turbo. Put my autometer water temp sensor in and put OEM sensors.
I put my JMF coil pack bracket on. I had to switch to two smaller 10mm bolts to fit it on.
I guess I'm just another victim of rushing, even though I've tried to take this project as slow as I can. I had to put the power steering bracket on and had to remove the water pipe to do it. I pulled it out and put a new layer of hylomar on there for good measure.
Bolted on the oil return line, First I cleaned off the crap on the oil pan with gasket remove (this stuff is really nasty, I got it on my skin and it instantly burned). I used black RTV and an OEM gasket along with the little 6mm bolts (yes defiant, one day I'll tap it to SAE )
____________________________
~Tom
Offline
[posts] [gallery] [blogs] Reply With Quote
Sponsored Links
