View Single Post
Old 12-21-2007, 11:19 AM   #32 (permalink)
blcknspo0ln
DSM Wiseman
blcknspo0ln's Avatar
Region: Tri State
Classifieds Rating: (4)
I greased the crankshaft prior to putting the front case in. Here's a pic of new guide pins for the block/front case:
Note the orientation of the balance shaft sprocket and crank trigger plate:
This is how I've always torqued that stupid crank bolt down. Just stuff a bunch of rags in the crank until it doesn't spin anymore. I used red loctite and torqued to 60 ft/lb on the bolt.
When bolting on the front case, MAKE SURE, you either use a sealant or RTV on this bolt, or else it will leak.
____________________________
~Tom
Online
[posts] [gallery] [blogs] Reply With Quote
Sponsored Links
