What year is the car ? You could get a junkyard TCU out of a non-turbo, if it will plug up (two plug or three plug ) than it will work if the TCU is your only problem...The shift points will be off...I've used a two plug 1.8L TCU in my 93 AWD just to see if it would work..It did, but the shift points were way too early..Different ratios, fwd.... Let me know if the TCU # is MD750092 ..
____________________________
93 at/awd, GT35R, 950's, MAFT, IPT restall
