95 'clipse RS
- 322
- 4
- Nov 2, 2004
Erlanger,
Kentucky
ok, i have searched this for awhile now and couldnt find anything to help me with this. im basically just wondering a few things about my setup and the typical things these trannys do.
ok firstly, i have a "stage 3 clutch" from sachs (ebay mistake), which feels ok and what not, but i do plan on changing that. it is a 6 puck sprung disc, with basically a little over stock PP, and aluminum alloy fly. modular setup. also, i swapped in a 3.55 03 neon tranny to go with it. i did have it apart, due to the syncro poppet balls coming out in the process of changing the shift levers. i inspected the roller bearings and races, and they looked normal, no signs of high temps, not pitted or anything, the shift forks had hardly any wear at all. also no signs of metallic shavings or anything of that manner. all reassembled fine, except for the fact that i forgot to lube the TOB and clutch release system.
now more to the point, i am getting a very noticeable whine in 3rd and 4th, both around 2k rpm. reverse feels pretty sluggish and gritty until clutch is fully engaged, a little bit of what sounds to be differential bearing wear, but too faint to tell really, could mistake it for road noise. also, on cold starts, the tranny makes a quite loud grinding sound, neutral with clutch engaged. then when i get a block away, it is basically silent. on this i was just wondering if it was normal for the tranny to make noise on start up being that the fluid has settled, or should it still be pretty quiet?
and on the other things, i really dont know. ive never had a tranny whine before. except for an auto or somethin. im just wondering on the 3rd 4th and reverse thing if that could be clutch chatter, or something to do with something other than the tranny. even with all of this happening, it doesnt really seem like its on its way out. it pulls hard and shifts fine, it doesnt feel loose or anything. i just want to make sure that this one doesnt break on me too.
any input, or similar experiences would be greatly appreciated.
thanks everyone
thanks everyone
. and so is the master rebuild everyting but the syncro rings? and i was kinda lookin for something more beefy than stock, is there anyplace for that? if not, its cool, youve been most helpful locke. next time i tear into one, im doin a write up on it also for anyone who has the same problem and needs a walk through.
