View Single Post
Old 10-29-2007, 02:50 PM   #128 (permalink)
InfiniteGSX
Proven Member
InfiniteGSX's Avatar
Region: Southwest
Classifieds Rating: (0)
Reputation: InfiniteGSX is more helpful than not
EclipseTrbo420A, Not to be a stickler... but what in the hell do you plan on doing about the door jambs? the area's behind the tail lights? All the other possible visible spots of white like where the antenna is... I mean, all this work your doing... you should get those area's done with something before you get to that shiny coat you've been working so hard on... and have to mask off all your lovely work.
I probably would have started out like you did... but would have used some Brake cleaner in the area's you couldn't paint ... Work my best on getting those area's able to take paint, and get some good rattle cans in that area... before touching the body.
I'm seriously thinking of building a sand blasting kit that I can use to sand area's like that down, perfectly... Cause I don't know about you... hand sanding things like that, sucks! I end up getting lazy and half assing the rest of it, or not finishing it.
____________________________
-Josh
1994 Eagle Talon TSI AWD
Offline
Sponsored Links
