Quote:
Originally Posted by talont3t4
Thanks for the info in my thread. Do you think instead of 3mm spacers I would be better to order 16*7 45mm offset for the fronts and 16*8 48mm offsets for the rear? That should eliminate the need for spacers correct?
What is the clearance issue, between the tire & the knuckle? If so, going to a 48mm offset is going to make the issue even worse, as it tucks the rim further in. If you need more clearance between the tire & the knuckle you want to run a smaller offset to push the tire further out (closer to the fender)
