MyEclipse5
- 2,737
- 1
- Oct 2, 2002
Normal,
Illinois
I can't boost over 5psi with my boost controller, and I've done many leak tests with no results. To check to see if its just me being stupid and not doing the test right, or my MBC/actuator/hardware failure I was wondering if there is a way to hook it up so that it SHOULD just boost unlimted.
I have an aftermarket boost controller, so as soon as it builds over 7psi I'll shut her down cause I enver get that high as it is.
Is there a way to do this?
. If you know that tapping off the BOV is not the proper way to get a boost source and you are troubleshooting a boost issue... how about doing things the correct way first and then go from there
