viperkd77
- 68
- Apr 29, 2004
Pittsburgh,
Pennsylvania
So lost. Here are 2 logs. One for cruise or closed loop. One for wot of open loop. I put on a 3inch catless xhaust in the fall. Got 20mpg before and now like 10mpg.
Previous mods were kn filter, custom intake pipe, mbc at 14psi, dump tube cut, bcs restrictor removal (before mbc).
since exhaust, in research of my problem ive replaced the 2g tb with a 1g tb and eliminates all boost leaks and have also got dsmlink (b/c i wanted it originally and...) to help see and eliminate this problem.
I've been advised that the exhaust is not causing this problem, but it is infact something else possibly. I actually lacked ground straps on the new exhaust that were on the stock exhaust. I replaced the one near the rear 02 (frame to clamp) just bc ive heard they were necessary (97 gsx a/t).
I am stumped. At wot, it seems more powerful with the exhaust. However, even if i let off the gas ever so slightly in cruise it runs awful (black smoke ,slow, boggy, eats gas). I was told that my fuel trims are decent at wot, but very rich at cruise and idle. I have no idea how an exhaust install can lead to this chaos. Maybe something happened in coincidence. Please help........
. i know that. The dump tube cut is something else. I am still recirculating....
