7"exhaust_tip
- 254
- 4
- Mar 11, 2006
Huntsville,
Alabama
i did a boost leak test yesterday. At about 1psi the e-ghey greddy style blow off valve that the previous owner had put on, seems to be leaking out of every side and bolt that it has.
I gave more and more psi but it couldnt hold past 5 in the system and was going nuts at the bov. (im going to post a vid later).
Will the boost gauge in my car still be showing about 12psi even though its leaking almost all of it at like 1psi? also, would this cause a vaccum leak at idle and a boost leak under boost?
boost leaks
