crank sensor wiring
TurboAnything
701
11
Jun 6, 2004
Carol Stream, Illinois
Im putting in a megasquirt in a friends car 99 N/T eclipse. I need to hook up the crank sensor trigger wire but i dont know what the three wires are. what are the color/tracer for power,ground,signal. Thank You
By the way how many people on this N/T fourm are around 500-550 Whp cause thats what im going for with his car and if so what are the common problems at that HP range?
The signal wire is blue/white, while the +9V source is yellow. Whatever color the other wire is, is the ground. I don't recommend disconnecting the ground/+9V from the ECU unless you can provide a very solid +9V source (there is some speculation that it can run off of just +5V, but do you really want to be a test subject?).
Things breaking. :thumb:
500whp, do some research if you going to ask that question. you friend will need to do a lot of supporting mods to make the car driveable for more than 15 secs.
You will need ot leave the factory ECU in the car and just tap off the crank signal wire. Also if you havent done so, you will need to cofigure the MS for the 420a code (unless the seller did it for you).
Ok well the car is fully built. everything except the trans
JE pistons 9:1
Crower rods
Forester Racing head fully ported 1mm oversized valves spring&retainers
Custom Big plenum intake manifold with 75mm accufab throttle body
Custom Tubular exhaust manifold with 38mm tail wastegate
Precision turbo SC61 turbo
full 3inch exhaust
Megasquirt With NGK wideband
Racing fuel cell with -6 lines and a inline 275lph pump
880cc precision injectors
Apexi skyline intercooler 3in inlet-outlet
3in aluminum piping with tail bov
and some 6 puck clutch that i didn't put in.
I will post pics soon
I have a feeling im going to need help getting the megasquirt to run good so you will be hearing from me a lot. :D
hmm ...
PICS please
The 3.55:1 is used in a Neon however i would not call it a neon trans. IT is a Nvt-350 3.55:1 final drive trans. Depending on the year Neon you get it from will decide what kind of alterations you will need to do to it before you install it.
Terry
here are some bad pics i will get some better ones when i go over there.
    • 92AWDHX40
    • eclipsemf
