Ludachris
Founder & Zookeeper
- 8,836
- 4,650
- Nov 12, 2001
Newcastle,
California
Cylinder Head & Short Block Forum Guidelines:
NO NEWBIE QUESTIONS - THEY WILL BE DELETED COMPLETELY!
This forum was created for the more advanced DSM enthusiasts in mind, specifically, those who have already modded their DSMs past the Stage 2 point (400hp). Unless you have extensive experience in the building, tuning, and repairing DSMs, you should post in one of the other forums. Everyone is welcome to read through and learn from these discussions, but please be aware that topics that don't belong in this forum will be deleted and you could get banned for not paying attention to this request. If you're not sure if the question is advanced enough to be posted in this forum, please post it in the Newbie Forum instead.
If you have not thoroughly read through the following resources, you should not be posting a question in this forum:
http://www.dsmtuners.com/tech.php
http://www.dsmtuners.com/parts/default.php
http://www.vfaq.com/
http://www.dsm.org/
or a DSM repair manual
Also, be forewarned that the moderating in this forum will be much more strict than in our other forums due to the level of technical discussions that will be held. Do not complain publicly about the moderation or the policies. Any off topic discussion within a thread (including complaints about moderation or warnings) will be deleted so that the thread's main content will be saved and added to. Be sure to use good grammar and punctuation, as all posts in this forum should appear to be written by an intelligent, educated adult who has something worthwhile to contribute. Complaints about moderation will also be removed in order to keep threads on topic.
Don't be offended if your post gets deleted. It will likely happen to plenty others who fail to follow these guidelines. For a good example of what is considered an "advanced topic", read through past threads and try and compare them to your own. If you've never performed anything more difficult than a timing belt replacement or clutch install, then you probably should revert to the Newbie forum.
One last note - if someone posts a begginer question, or something that does not belong here, nobody is to make fun of the question or the person asking it. Mistakes happen. Report the post to a moderator and move on. Starting a flamewar by rousing the person will just get you kicked out of here.
Happy posting.
http://www.dsm.org/
Happy posting.
