View Single Post
Old 06-25-2004, 02:35 PM   #6 (permalink)
GSGoinFast
DSM N/T Wiseman
Region: Midwest
Classifieds Rating: (0)
Reputation: GSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening toGSGoinFast is an experienced, knowledgeable member worth listening to
7) the white wire. the white wire is the TPS(Throttle Postition Sensor) wire, which tells the smart box when you are at wide open throttle. there are 3 wires on the TPS, but the one i needed, and ive heard its the one for everyone, is the Red/Brown wire. you may want to use a volt meter to make sure. mine threw .6v at no throttle and around 4v at full throttle. good enough. i used the red crimper that came with it and crimped it on the red/brown wire, and then connected the white wire to it with a red male plug thats provided. once again, clamp it down with pliars, and electrical tape it.
Offline
Sponsored Links
