Darktalon92
- 56
- 1
- Dec 20, 2003
Gananoque,
I have the big brake upgrade on my 1g with slotted front rotors, stock rear, Hawk HPS front pads and KVR carbon rears with SS lines. Last year the brakes were awesome but now after just normal street driving, no track time yet it seems that the brakes have lost it. I mean I can put the brake pedal to the floor and with the clutch in or out I can not lock them up. Now I did over the winter remove the ABS and install non-abs lines and proporting valve, I bled all brakes and there was no noticable air in the lines, at most there was tiny tiny little bubbles that you could barely see.
I plan on bleeding the front brakes tonight to see if that helps, but could it have anything to do with the pads?
Reason I ask it that I'm going to try out some Solo2 racing for fun Thursday and want to have things working right by then.
Thanks
Thanks
