Street Build 2G HX-35 A/C Auto-X & Daily
Ownership Status
No Longer Own
Mitsubishi Eclipse GSX
Drivetrain
AWD
Build Type
  1. Street
Holset HX-35 in BEP .55 AR DSM housing, Evo3 exhaust manifold, VRSF FMIC, Synapse Engineering BOV, RRE Down Pipe and Test Pipe, Espellier 3" Exhaust, Walbro 450LPH e85 pump, -6 AN Fuel line tank to rail with Fuel Lab Filter, RC 1200cc injectors, Fuel Lab AFPR.
Mods-Engine
6-Bolt Block, Stock Crank, Manly H-Beam Rods, Wiseco HD pistons, Moroso oil pan, 2G head, Kiggly HLA, Kelford 272 cams, 1mm oversized valves, stock extrude honed intake manifold, AEM Cam gears, '90 oil filter housing with B&M oil cooler
Mods-EMS & Logging
ECMLink V-3 set up for speed density and e85, Zeitronix ZT-2 Wideband with oil pressure sensor and alarm box. Zeitronix Ethanol Content Analyzer.
Mods-Drivetrain
TRE Stage 4 Transmission with Quaife front differential and welded center differential, 10% taller 5th gear. ACT 2600 with sprung 6-puck disk.
JIC coilover suspension set up by Muellerized, Gram Light 57 Maximum 17X8, 235/45/17 Hankook Ventus V2 Concept2 tires (street use), Stock Evo VIII wheels, 235/45/17 Bridgestone Potenza RE-71R tires (fun use). EVO brakes front and rear with drilled and slotted rotors. RRE front strut bar, RM Racing rear sway bar, Volk Metal Works front lower control arms.
Parts Wishlist
FP Green to replace the holset, bigger injectors.
Background
I bought this car mildly riced out in 2005 and it has been a fun time ever since I saved it. I just want it to keep being my quick daily driver.
1/8 Mile E/T
7.956
1/8 Mile MPH
91.61
Timeslip Photo Link
Timeslip Details
Full weight, HX-35, e85, 29psi, RE71R tires, summit motorsports park, shootout 2017
Dyno HP
451.8 whp
445.3 lb/ft
Dyno Type
Dynapack
Dyno Sheet Photo Link
Dyno Shop Name
Road Race Engineering
Dyno Session Details
Holset HX-35, 2.3L, FP-4R cams, e85.
Videos
I added a new video of a launch and 1-2-3 pull. Just out having some fun with the GSX.
SOADweskey
Comments
6
Rating
5.00 star(s) 3 ratings
Share this Vehicle
