Leo
- 1
- Sep 26, 2015
Stockton,
California
I just recently bought a 98 gst spyder with 53k original miles. I was wondering which type of oil I should put in it conventional, synthetic, or semi-synthetic. Please help me out
Note: This feature currently requires accessing the site using the built-in Safari browser.
Blue? Mines always been golden. It gets dirty pretty quick but is good stuff. All the bearings and everything are still shiny and smooth.Congrats on the purchase and welcome to the forum. Opinions very greatly, but generally use a full synthetic. A lot of guys on here use Valvoline VR-1 Racing Oil (the blue stuff). I really love Shell Rotella T6 in 5w40. It is technically a diesel oil, but it's great for high heat applications and has lots of good additives in it.
Mobil 1 isn't good like it used to be. Its been watered down. Look at that link about oils by FP they created a thrust bearing failure by using it.Thanks but What about Mobil 1 ?
They must've changed it. I've been using it for close to 2 years now and its always been gold bronze in color.I'd double check which oil you're buying if it's not blue Unless they changed it! The last time I used it was in 2012 and it was definitely as blue as a berry Jolly Rancher.
a mix of 20w-50 and 10w-30 for when its colder here (40-70 degrees) and straight 20w-50 when its warmer (60-90 degrees). Out motors like thicker oil. I guess the thicker oil provides more support in journal bearings and things. Its advised to at least use 10w-30. Most mild to modest builds (300-400whp) run 15w-40 or 20w-50. A majority of guys run 20w-50 for higher HP stuff in moderate to warm climates like here in california. FPs Evo ran Brad Penn 20w-50 per that link provided by weasel1GWhat weight do you guys run?
I agree. Ive used only mobil 1 for years and just made the same switch. It gets super thin.I really hate Mobil 1. In mgperience it gets extremely thin very fast and none of my motors ever sounded quite right with it. I've used Mobil 1 in my BMW E36, my 2G, and some trucks. Blegh. I use Castrol Edge Extended Performance in my Tundra and it's awesome as well, just a bit spendy per quart depending on where you get it. For shorter oil change intervals in cars you beat on (DSMs..) I'd use Rotella honestly. It can be had for cheap at Walmart. Other than an OEM filter, WIX would be your best bet for a local buy. WIX is by far the best parts store filter.
