2G Transmission Repair Manual?
Do a Google search for w5m33 transmission service manual.
http://www.3sx.com/faq/manuals/Service-Manual-Transmission-FWD-Mitsubishi-Manual.pdf
http://www.scribd.com/doc/17887193/MT
Shim specifications (Stock and performance): http://www.4gtuner.com/topic/13929-w5m33-gearbox-info/
Torque Specifications:
Main Case Bolts 29 lb/ft
End Shaft Nuts 102 - 115 lb/ft
Poppet Plugs 18-22 lb/ft
End Cover Bolts 29 lb/ft
Reverse Gear Shaft Bolt 29 lb/ft
Reverse Shift Bracket Bolts 11 - 15 lb/ft
Reverse Shift Bracket Hex Bolt 11 - 15 lb/ft
Reverse Brake Cone Screw 4 - 5 lb/ft
Restrict Ball Bolt 22 - 25 lb/ft
Reverse Switch 22 - 25 lb/ft
Speedo Gear Retaining Bolt 3 - 5 lb/ft
Center Differential Cover Bolts 55 lb/ft
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
