Timing tensioner tool
Why pay for an expensive tensioner compressor tool when you can easily make one yourself for about $5?
Tools needed:
-tap and die kit
-dremel/ rotary tool or grinding wheel
-5/16 mild steel rod
- one or two nuts
-spray lubricant of some sort (Wd-40,spray silicone)
-welder (optional)
1. Buy a 5/16 mild steel rod from home depot
2. Measure 12 inches of the rod and cut it. (dremel cut off wheel , etc)
3. Place the rod in a table vise or you can use vice grips like i did.
4. Slightly taper one end of the rod with a dremel/ grinding wheel. (Enough to get the die on the rod)
3. Spray wd-40 or lubricant of some sort on the rod
4.Use a 8mmX1.25 die and thread the rod 6 inches
5. Weld a nut on the other end or Thread the other side about a half inch and find two nuts to fit.
6. Thread on one nut as far as it will go and then thread the other right on top
Now you have a cheap and reusable tensioner tool.
I suggest when using this tool to spray some sort of lube or anti-seize to prevent the rod from sticking.
