Rear Differential Identifiers??? Manual vs Automatic
BoostedBeaver
Moderator
957
291
Aug 15, 2009
Augusta, Georgia
I have been shopping for a four bolt, and will be picking it up Saturday. I do trust the gentleman that I am picking it up from, but I must check the rear myself. I am wondering the means and ways of identifying the difference from the auto 4 bolt rears to the manual rears. Also a quick way to determine 1g or 2g. Here is what I have come up with so far.
1G cars have cups that are held to the axles by bolts.
2G cars have a rear axle that is held in by a nut. The axle slides into the diff, the wheel side of the axle is slid through the knuckle assembly and held in by a nut. This is much like the front axle design.
1g 90-91 rear service info.
2g 97-99 rear service info.
One sure fire way to check the rear is to count the ring and pinion gear teeth. By doing this you will verify and have no doubt of what rear you are getting. You can see above that all years (90-99) use the same gear reduction type. All manuals use a 3.545 reduction ratio while all automatics use a 3.307 reduction ratio. Drive gear teeth and pinion gear teeth vary based on AT or MT and viscous LSD or conventional diff. Use the chart above to find out what diff is in front of you.
I do not know any of the codes on the rear diff covers. I know that the combination on the rear diff cover is not a sure fire way to check the diff, but it would be a good fast check. If you know the codes (B1G, B1H, B1J) and which vehicle they belong to, that would be great. Any additional info would be great. Hope this information helps others and I know it helps me.
Robert
Thanks for the replys and checking the parts that you had. From the info that I have gathered all the above information is correct. There are some above that I would like to find out what they belong too. Once we can verify this, I will update the origional post.
Thanks again.
So far I have come up with the following info. This information was compiled by talking to other DSM'ers and getting them to look at their diff.
Another way to tell the difference between a 1G and 2G differential when it is out of the car is.....
"The 2G bolts up with three bolts on each side of the nose cone and two on the rear cover. The 1G bolts up with two on top and one on each side of the housing. Then it has two on the cover just like the 2G." (1gkfwd link forums)
If you are lucky enough, the diff will still have a sticker. This sticker will state the reduction ratio. This is a good Identifier of what car it belongs to. Keep in mind that covers can be changed. Look at this link for a picture from WES_393 on Tuners
http://www.dsmtuners.com/forums/152988201-post3.html
1G AWD Auto - 3 bolt LSD - J1G
1G AWD Auto - 4 bolt LSD - J1H (2highpsi and 1gkfwd link forums)
1G AWD Manual - 3 bolt LSD - B1G
1G AWD Manual - 4 bolt LSD - B1H
2G AWD LSD Auto - JFH (1gkfwd Link Forums) BFB (WES_393 Tuners)
2G AWD LSD Manual - BFH
Diffs that we still need to identify are
All Conventional diff models. (There are two types of diffs. One is the LSD's which seem to be the most common and conventional diffs which I have yet to see)
All 2G models
Please verify that the numbers you post are correct by either counting the ring and pinion teeth or by using the diff in your car for a period of time with no ill effects. I am not asking people to open their rear diffs if they are in use on the car, just rear the numbers and post them up.
Robert
For 2g's this is what I have gathered.
2g LSD Manual: BFH
2g LSD Auto: BFB
Not sure about 2g Non-LSD.
The rear diff cover will state the reduction ratio right after the Japanese characters. That should make identification much easier.
2g LSD Manual: BFH
2g LSD Auto: BFB
Can you verify the BFB number for the Auto LSD???? Just asking because there is another member with a 2G Auto LSD diff with the number code JFH???
If you did post the correct numbers, what year model car did this diff come out of if you know????
Thanks for your input.
Robert
What if the diff. has a different cover on it? How can you identify what diff. you have?
This is a good question!!! The covers can be changed over and/or swapped, so just the number on the case is not always a sure fire identifier. If the case has grey sealant, there is a good chance it is the factory sealant. If there is any doubt, you will have to pull the 8 bolts and count the teeth like mentioned above. Use the service manual (or images above) to find out which diff you have after counting the teeth.
Robert
I also added the 1G 3 bolt non lsd on link. The one I have here is B11.
To varifiy that the cover is correct counting the teeth is a for sure way of knowing. Also youll be able to see the Vicious in there to know if its LSD or not. Other way of checking that is the non lsd axle will fit in both sides.
I want to contribute as much as I can to this since this subject seems very confusing.
In the first post, second picture, it says Conventional Diff A/T - 3.545 and Conventional Diff M/T - 3.307. This MUST be a misprint because every other DSM FSM/TECH manual contradicts it. I searched around and could not find anyone with a 3.307 rear end coupled to a manual trans -and vice versa, no 3.545 diffs coupled to auto transmissions. So basically, auto is 3.307 and manual is 3.545. Nothing else.
I also wanted to note I have a 97' GSX M/T with a NON-lsd rear end. It is labeled BFB 3.545. I have found 2G's are rare for LSD type differentials since they were only an option. And I'm not happy about it, by the way.
SO, what we have here is a good bit of confirmation, enjoy!
2G Viscous-type LSD differential coupled to a M/T is labeled:
"Viscous LSD
BFH
***3.545"
Post No. 1, + Pictured
2G conventional-type differential coupled to a M/T is labeled:
"BFB
***3.545"
Post No. 5, + Pictured
2G Viscous-type LSD differential coupled to an A/T is labeled:
"Viscous LSD
JFH
***3.307"
Post No. 1, 5, + Pictured
Post No. 145, + Pictured
Post No. 2
2G conventional-type differential coupled to an A/T is labeled:
"JFB
***3.307"
Post No. 127
*** = The Japanese characters
    • george bromwell
    • pma1123
    • Sdcryan1
