wishihadatalon
- 2,616
- 76
- Aug 18, 2002
Grand Rapids,
Michigan
Alright guys, I did a search and wasn't able to find anything helpful to my situation. The story goes like this. I received this car (90 gsx) from my co-worker for free with a blown motor and half buried in a field from sitting for 6 years. Original intent was to part the car but now I am changing the engine out for a winter tank.
So after getting the engine out, I assessed the wiring harness and found that many of the wires were chewed by field mice. I got them pretty much all fixed (cut out corroded sections, solder in sections to fix) and installed an SAFC and Zeitronix wideband. I also removed a VPC and Viper alarm/remote start. Now I have put a battery in the car with no engine or sensors and when I key the car on, I get no power to the SAFC, wideband, or ecu. I have power to pin 103 (constant 12v) but nothing to 102 (power source). I verified I am getting power to pins 10 and 3 on the MFI relay but I don't get power to pin 9. I'm also not hearing the fuel pump come on (I've heard different things about the pump not starting until the car cranks). Also if I key the car to the start position, I can hear the MFI click but then my radio cuts out.
My trouble here is that I can't find a schematic to trace the wires back from the ecu to ignition (assuming my issue is between these 2). I have accepted that I may be looking in the wrong direction and/or may not have a complete understanding of what I am doing. Any pointers to get me going in the right direction or better schematics than the FSM or Haynes manual would be greatly appreciated.
Thanks,
TJ
Thanks,
TJ
