Is this oil on my spark plugs? (pictures) Shiny/brown on insulators...
Gremo87
128
Mar 14, 2013
Decatur, Illinois
Been having issues with my new car - 94 GSX, details in profile - engine rebuilt by original owner less than 3000 miles ago, but I just pulled these sparks plugs that have less than 50 miles on them - maybe less than 30 - and here's what I found. 2 images for the 3 oily (?) plugs - one with flash and one without.
Cylinder 1:
Cylinder 2:
Cylinder 3:
Cylinder 4:
If this is oil....then it's likely rings, valve stem seals, or HG right? Next up will be a leakdown test I suppose....
I've never seen any smoke coming from the exhaust - not on startup, accel, decel, etc - never.....and the exhaust has never smelled like oil the few times I've put my nose to it. Could be only happening under heavy load I guess, but......thoughts?
Hmmmmmmmm, well, I guess that would make more sense, as my compression numbers are good...
But then this raises another question - why would cylinder #2 be the only one unaffected, which also was the case with my last set of plugs. (seen below)
Cylinder 2 had and has a much cleaner appearance...does that indicate anything?
I've read what causes insulator glazing, and have read suggestions to use a colder plug. Thing is, I just went from BPR6ES (picture above) to BPR7ES (pictures at beginning of thread). 6's are hotter so I would think they'd have shown glazing as well....not sure what direction to go in here.
Though I just read that it can be an A/F mixture issue too - and my car definitely needs tuned.
Hmmm....
  • Wanted 4G63 Wanted
    Looking for a kiggly HLA
    • steelcurtaindsm
  • For sale 2g 1998 Eclipse GST Rust Free
    Rust free, not perfect, prob needs motor soon. 125 compression all 4
    • Zanaqqq
  • For sale 1g Int door plastics MB517837 and MB517834
    • ist dwa
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted FIC Easytune
    Looking for a FIC Easytune box.
    • Stapl3
