Innovate LC-1 Installation Options
Posted by snowborder714, Dec 2, 2011
  1. snowborder714
    snowborder714 Moderator
    11,905
    193
    Joined Oct 15, 2006
    Mechanicsburg, Pennsylvania
    Updated to remove LM Programmer usage as it seems to be causing people a lot of trouble. Still retained one example using LM Programmer all the way at the bottom for reference.
    One question that pops up very often is how to hook up your Innovate LC-1 wideband controller. I figured I would put together a listing of the many different configurations that I have seen people ask about. These will be broken down by vehicle generation for logging purposes.
    1G
    Make sure when cutting the front o2 wire (white wire at pin 4 location) that you're NOT cutting the knock sensor wire. Make sure there's a BR (Black/Red) and YB (Yellow/Black) wire on either side of the white wire you cut.
    Do not put the blue wire to sensor ground as you will blow the ECU's sensor ground track.
    Basic install (DB gauge, No logging) [LC-1 placed in new bung]
    Red wire – 12v accessory power source (e.g. cigarette lighter or radio)
    Blue wire – chassis ground
    White wire - ECU sensor ground (pin 24)
    Brown – DB gauge’s white wire
    Yellow – Not used
    Black – Calibration push button to monitoring LED to ground
    Basic install (DB gauge, Logging) [LC-1 placed in new bung]
    Brown – split between DB gauge’s white wire and ECU pin 15 (ECU Pinout - http://www.dsmlink.com/images/forums/1GECUPinout.pdf)
    Yellow – Not used
    Narrowband simulation install (DB gauge, Non-logging, Non-ECMlink v3 setup) [LC-1 sensor placed in front o2 spot]
    Yellow – ECU pin 4 (ECU Pinout - http://www.dsmlink.com/images/forums/1GECUPinout.pdf)
    Narrowband simulation install (DB gauge, Logging, Non-ECMlink v3 setup) [LC-1 sensor placed in front o2 spot]
    Narrowband simulation install (DB gauge, Logging, ECMlink v3 setup) [LC-1 sensor placed in front o2 spot]
    Brown – split between DB gauge’s white wire and ECU pin 15 or pin 4 (ECU Pinout - http://www.dsmlink.com/images/forums/1GECUPinout.pdf)
    Yellow – Not used
    Narrowband simulation is then done inside the v3 software - v3narrowbandsim [ECMTuning - wiki]
    2G
    Basic install (DB gauge, No logging) [LC-1 placed in rear o2 spot or new bung]
    White wire - ECU sensor ground (pin 92)
    Yellow – Not used
    Basic install (DB gauge, Logging) [LC-1 placed in rear o2 spot or new bung]
    Brown – split between DB gauge's white wire and ECU pin 75 (ECU Pinout - http://www.dsmlink.com/images/forums/2GECUPinout.pdf)
    Yellow – Not used
    Yellow – ECU pin 76 (ECU Pinout - http://www.dsmlink.com/images/forums/2GECUPinout.pdf)
    Brown – split between DB gauge’s white wire and ECU pin 75 (ECU Pinout - http://www.dsmlink.com/images/forums/2GECUPinout.pdf)
    Brown – split between DB gauge’s white wire and ECU pin 76 (ECU Pinout - http://www.dsmlink.com/images/forums/2GECUPinout.pdf)
    Yellow – Not used
    *Note – The brown and yellow wires can be swapped in this scenario.
    DB Gauge
    White wire – Signal output wire from LC-1 (either brown or yellow – see above for which)
    Yellow wire - Non-dimming illumination (e.g. headlight wire)
    Red wire - 12v accessory power source (e.g. cigarette lighter or radio)
    Black wire - Same ground source as LC-1 blue wire
    XD-16 Gauge
    Red wire – Same power source as LC-1 red wire
    Black wire - Same ground source as LC-1 blue/white wires
    Serial IN – connect to Serial OUT port on LC-1 controller using the male 2.5mm stereo to male 2.5mm stereo cable
    Serial OUT – Not used
    *If using the XD-16 gauge, the black wire on the LC-1 controller is not used.
    For those of you who still need the rear o2 functional to pass emissions, this suggestion was given to me by gofer.
    LM Programmer usage scenario for reference. Not recommended to follow.
    2G
    Brown – ECU pin 75 (ECU Pinout - http://www.dsmlink.com/images/forums/2GECUPinout.pdf)
    Yellow – DB gauge’s white wire
    (*Must reprogram Analog Out 1 values to match Analog Out 2 values using LM Config 3.15. Screenshots and software - innovatelc1orlm1install [ECMTuning - wiki])
    Log in/Register to remove ads
    My DSM:
    1995 Mitsubishi Eclipse GST
    12.529 @ 110.820 MPH
    Loading...
    gofer likes this.
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
