How to Measure, Mic, a Piston
BogusSVO
5,886
337
Jul 1, 2009
Pensacola, Florida
Supertech PN# P4-MA835-N4
Factory supplied spec sheet.
They ask for a bore spec 3.287/83.50 mm, This what is your recommend bore size.
Tools needed for the procedure, Outside micrometers 3-4 inch,
But in a pinch, venire calipers will “Get you close” if just doing a quick check
A machinist standard is handy to have, so you can zero your measuring tools.
The points you want to measure 90* to the wrist pin centerline
A view of the appox pot to measure from, with venire caliper.
All 4 pistons in the box measured 3.2845
This is going to be Piston to Wall clearance, PTW, in theory. Your actual PTW will vary due to cylinder block finish.
The factory spec sheet says 3.287”/83.50 mm
The formula for converting mm to inches is
Mm x .03937 =Inches
83.50 x .03937 = 3.287395
Now to figure PTW (Theory)
3.287 – 3.2845 = .0025 PTW clearance
I am more accustomed to seeing .0035, but that is on a 85mm piston, and other brands of forged pistons.
That also could be in part due to the “Phosphate dry lubricant”
From the super tech website
SURFACE FINISH:
Finally our "phosphate dry lubricant" coating is applied to protect the rings against "micro welding" and enhance lubrication on the skirt/cylinder area.
Piston Rings are manufactured in Japan with the latest technology for high performance applications.
Quality Control: Performed after every step of the manufacturing process in climate controlled environments to ensure reliability of dimensions.
Supertech - Products - SuperTechPerformance.com
Figured I would reply to this with a bit of information.
Supertech Pistons are actually manufactured by Mahle Pistons which use 4032 alloy and not the normal 2618 which expand more than the 4032.
Generally piston to wall clearance can be tighter. I am running anywhere from .0028" to .003" on a 6-700hp build with these pistons.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
