How many bolts for oil pump?
dsmalaska
75
Dec 18, 2013
Avondale, Arizona
Okay I can not find this info anywhere. I'm about to put my oil pump on but I have (5) short bolts with the number 4 on them. I know they go with the oil pump but I feel like there should be more bolts for the extra holes. It's been 5-5 1/2 months since I took the motor apart(machine shop took there sweet time..) so I kind of forgot where it all went. :ohdamn::idontknow: any help would be awesome!
Are you talking about the entire front case or the oil pump cover (bolts to backside of front case)?
The front case has 12 bolts:
And the oil pump cover has 5 bolts:
Okay so I found my box with all my old tensioners,water pump, etc with all the bolts but I still don't where they go... I had them put with what they went with but must have fallen out when I was movin the box around.
Talking about whole front cover
The front case has 11 bolts:
Awesome that helps out a lot! But it doesn't show all the other bolts...
All that "helpful" diagram says is the wrench or socket size needed for the original bolt heads. If you're going to use something to identify what goes where, use the diagram provided in post #2. The hydraulic tensioner bolts are 51mm but have a neck down and should be fairly obvious.
The original bolt for the balance shaft tensioner is 45mm long; if you're eliminating the balance shafts, you need a bolt 16mm long.
  • For sale 2g Early 95 2GA DSM Hardtop for sale (5-speed)
    2G DSM for sale
    • codexes21
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
