Holset Part # Thread Only!!!!
Slippi84
4,454
20
Jun 8, 2005
Cinnaminson, New Jersey
Ok there are a million and one pages from the holset thread and a big portion of it lately has been people asking for part numbers for a specific turbo. This thread will be for people to post what the part number of they're turbo is and state how it CAME not how it IS. Meaning if you bought a turbo with xxxxx part number then bought the BEP housing don't say this part number is for x turbo with bolt on housing. If you have a question about a turbo make sure you look threw this thread before asking yoru question. They're really shouldn't be that many question in here more post. These are the things you want to post that will help identify the turbo and if that part number is what someone else is looking for:
Turbo(hx40, hx35, hy35, h1e, hx52 ect..)
Blades(6,7,8 ect..)
Hotside IT CAME WITH!!(14cm, 16cm,18.5cm, T3 T4 T6 Bolt on wether or not it's internally gated or excternally gated the way it comes, how big is the exhaust outlet ect..)
Wether it's a Pro or not(If you don't know for sure don't assume)
Billet or not(People are starting to come out and say the billet may not be real and may not be worth the hassle but none the less if you have a billet wheel state so)
PICTURES( The saying a picture says a thousand words is always true)
Remember this is not for asking about performance or anything thing else other than part numbers as there are 4 parts of the actual holset threads with info on that. This is mearly to keep the main threads from becoming endless part number request by people who may legitimatly want a holset but don't want to or can't locate the info they need from 10000000000 pages of info.
HX52 with billet wheel t4 hotside(not sure the actual size or ar ratio. 7 blade 4.5" OD v-band exhaust outlet
Part numbers for the hx40 pro (super40) compressor wheel and compressor housing. If you'r swapping this to an hx35, you need to machine your backplate slightly, not expensive to do at all.
Pro wheel: 3599550
Matching housing: 3539026
Holset h1c 54mm 8-blade compressor, what I term the big h1c since there's a 50mm and 44mm h1c. 18cm^2 or 22cm^2 turbine housing. Fits in any hx35 turbine housing. The big h1c comes off of the INTERCOOLED dodge cummins ram pickups and has the webbing for MWE but no actual groove cut in: Assembly number 3531456.
Holset wh1c 56mm 8-blade compressor, has the webbing and the groove, 12cm^2 turbine housing. The same turbine housing size and identical compressor specs to the 1994-1998 hx35. Fits in any hx35 turbine housing. Comes off a 1994 only dodge cummins ram pickup: Assembly numbers 3533320, 3533564, 3534369, 3534370, 3536045, 3536046, 3802586
Holset wh1e, 58mm 8-blade compressor. This particular assembly number is not very common. But all h1e turbos are practically the same. Fits in any hx40 turbine housing. Mine was a new unit intended for a 1994 C Series Cummins Transit Bus: Assembly number 3535870.
Holset wh1e, this is from a cummins agco tractor. This turbine wheel apparently is larger than the hx40 turbine wheel and will not fit in an hx40 turbine housing: Assembly number 3802663.
Manufacturer/ Truck - Machine Model/ EngineModel/ Turbo Type/ OEM Partnumber/ OEM fitted Turbo
Case
Case Tractor Cummins 4ta390 H1c J906602 171270
Case Tractor Cummins 4ta390 H1c J908293 3535381
Case Tractor Cummins 4ta390 H1c J914130 3535381
Case Tractor Cummins 4ta390 H1c J919129 3535381
Case Tractor Cummins 4ta390 H1c J919130 3535381
Case Tractor Cummins 4ta390 H1c J919133 3535381
Case Tractor Cummins 4ta390 H1c J919135 3522900
Case Tractor Cummins 4ta390 H1c J919139 3528743
Case Tractor . H1c J907027 3802289 3522778
Case Tractor Cummins 6t590 H1c J907028 3528741
Case Tractor Cummins 6t590 H1c J907029 166592
Case Tractor Cummins 6t590 H1c J919113 3528741
Case Tractor Cummins 6t590 H1c J919115 3528741
Case Tractor Cummins 6t590 H1c J919117 3528741
Case Tractor Cummins 6t590 H1c J919121 466563-0003
Case - Cummins 6ct H1e J919199 3528777
Cummins
Cummins - 4bt H1c 3802295 3528755 3524121
Cummins Komatsu 6bt 110hp H1c - 3537190 3537189
Cummins Eea Tokyo Eea Hx27w 4025136 3593379 3593378
Cummins Komatsu-elite Ind 4bt 110hp Hx30w 3800709 3592016
Cummins Komatsu-elite Ind 4bt 110hp Hx30w 3800709 3593089
Cummins Komatsu-elite Ind 4bt 110hp Hx30w 3800709 3593090
Cummins Werklust Loader 6b Hx30w 4089772 4036882
Cummins - 4bta 130hp Hx30w 3802906 3592122
Cummins - 4bta 130hp Hx30w 3802906 3592123
Cummins - 4bta 130hp Hx30w 3802906 3592124
Cummins Truck 250hp Hx35w 4025154 3593155 3597179
Cummins Truck (dennis) 250hp Hx35w 4025154 3598716
Cummins 1996 Off Highway 6bta Hx35w 3802696 3536322
Cummins 1996 Off Highway 6bta Hx35w 3802696 3536323
Cummins 1996 Off Highway 6bta Hx35w 3802696 3536324
Cummins 1996 Off Highway 6bta Hx35w 3802696 3536325
Cummins 1996 Off Highway 6bta Hx35w 3802696 3536326
Cummins 1996 Off Highway 6bta Hx35w 98331221 3536321
Cummins 1996 Off Highway 6bta Hx35w 3802767 3536971
Cummins 1996 Off Highway 6bta Hx35w 3802767 3536972
Cummins 1996 Off Highway 6bta Hx35w 3802767 3536973
Cummins 1996 Off Highway 6bta Hx35w 3802767 3536976
Cummins 1996 Off Highway 6bta Hx35w 500395274 3536976
Cummins - 6bt Hx35 3802770 3537132 3537132
Cummins - 6btaa H1c 3802391 3531456 3531696
Cummins - 6btaa Wh1c 3533564 3534241 3534241
Cummins - 6btaa Wh1c 3534369 3534241
Cummins - 6btaa Wh1c 3534370 3534241
Cummins - 6btaa Wh1c 3536045 3534241
Cummins - 6btaa Wh1c 3536046 3534241
Cummins - 6btaa Wh1c 3802586 3533563
Cummins - 6ct Hx40w 3802651 3535635 3535635
Cummins - 6ct Hx40w 3802859 3537130 3537130
Cummins - 6ct-240 Hx40w 3802810 3537127 3537127
Cummins - 6cta H1e 3802257 3528789 3527107
Cummins Industrial 6bt-6ct-6cta H1e 3802303 316348
Cummins Industrial 6bt-6ct-6cta H1e 3802303 3524035
Cummins Industrial 6bt-6ct-6cta H1e 3910877 3524034
Cummins Industrial 6bt-6ct-6cta H1e 3919201 3524034
Cummins - 6bt H1e 3528778 3524034 3524034
Cummins - 6cta H1e 3530716 3524034
Cummins - 6cta H1e 3535456 3524034
Cummins - 6cta H1e 3535457 3524034
Cummins - 6cta H1e 3802303 316468
Cummins - 6cta H1e 3910877 3524034
Cummins - 6cta H1e 3919201 3524034
Cummins Bus Lta10 H2c 3801489 3519092 3519092
Cummins Bomag M11 Hx50 3804546 3594809 3594809
Cummins Bomag M11 Hx50 4024969 3594809
Cummins Diamond-delta Plus M11 Hx55 4039173 3590044
Cummins - M11 Hx50 3803939 3537245 3803939
Volvo
Volvo F4/fl4 Td40a H1c 1545644 3522715 3522715
Volvo F4/fl4 Td40a H1c 1545862 3522715
Volvo - Td41g H1c 422704 3524709 3524709
Volvo - Td41g H1c 5003263 3524709
Volvo - Td45 H1c 4881650 3523677
Volvo - Td61 H1c 864493 3528922 3528922
Volvo Fl6 Td61g H2a 420521 3523296 3524560
Volvo Fl6 Td61g H2a 5003086 3524560
Volvo Firepump Twd710fp H1e 866779 3531199 3531198
Volvo - Td71g H1e 471740 466588-0001
Volvo - Td71g H1e 471897 466588-0002
Volvo - Td71fg H2a 847860 3523649 3523649
Volvo - Td71fg H2a 4835338 3523649
Volvo - Td71fg H2a 8107135 3523648
Volvo - Td71fg H2a 8107560 3523648
Volvo - Td73e-es H1e 477653 3530669 3530669
Volvo - Td73e-es H1e 849680 3530669
Volvo - Td73e-es H1e 8112407 3530669
Volvo - Td73e-es Wh1e 477835 3533741 3534617
Volvo - Td73e-es Wh1e 477836 3533741
Volvo - Td73e-es Wh1e 477866 3533741
Volvo - Td73e-es Wh1e 477867 3533741
Volvo - Td73e-es Wh1e 477869 3533741
Volvo - Td73e-es Wh1e 477888 3533741
Volvo - Td73e-es Wh1e 477889 3533741
Volvo - Td730me H1e 3825928 3537551 3537551
Volvo - Txd73 H1e 865752 3532296 3532296
Volvo Bus D7 Hx40w 1549717 3593977 3592589-d
Volvo Bus D7 Hx40w 1549810 3590850
Volvo Bus D7 Hx40w 3919198 3592590
Volvo Bus D7 Hx40w 3978862 3596138
Volvo Bus D7 Hx40w 8113605 3592590
Volvo F10/b10m Bus Td100-101g H2c 846652 3518613
Volvo F10/b10m Bus Td100-101g H2c 1545074 3518613
Volvo F10/b10m Bus Td100-101g H2c 1545097 198639
Volvo F10/b10m Bus Td100-101g H2c 4002205 3518613
Volvo F10/b10m Bus Td100-101g H2c 5002206 465922-0002
Volvo Fl10/n10 Td101f H2c 1545281 3518911
Volvo Fl10/n10 Td101f H2c 1545347 3518911
Volvo Fl10/n10 Td101f H2c 1545348 3518911
Volvo Fl10/n10 Td101f H2c 5002759 3518911
Volvo Bus Td102f H2d 422923 3526059 3526059
Volvo Bus Td102f H2d 422938 3526059
Volvo Bus Td102f H2d 479023 3526059
Volvo Bus Td102f H2d 479116 3526059
Volvo Bus Td102f H2d 5003388 3526059
Volvo F10/fl10 Td102f-td103e H2d 422856 3525994 4027373
Volvo F10/fl10 Td102f-td103e H2d 422934 3525994
Volvo F10/fl10 Td102f-td103e H2d 5003367 3525993
Volvo F10/b10mk3 Bus Thd102kd-thd103k H2d 424778 3526465
Volvo F10/b10mk3 Bus Thd102kd-thd103k H2d 5003438 3526465
Volvo Fl10s Thd102kb-kf-thd103 H2d 424819 3526967 3591768
Volvo Fl10s Thd102kb-kf-thd103 H2d 5003439 3526967
Volvo Fl10s Thd102kb-kf-thd103 H2d 8113575 3591255
Volvo Fl10s Thd102kb-kf-thd103 H2d 8194707 3526967
Volvo Fl10s Thd102kb-kf-thd103 H2d 8194708 3526967
Volvo Bus - Hx52 20545143 4036438 4036437-d
Volvo Bus - Hx52 20494292 3598985
Volvo N12 Td120g-td121f/g H2d 863501 3526963
Volvo - Tad12320g 450hp H3b 865966 3533099 3533098
Volvo - Tad12320g 450hp H3b 866665 3533098
Volvo F12 123e (400hp) Td122f H2d 470931 3525408
Volvo F12 123e (400hp) Td122f H2d 470931 3526008
Volvo F12 123e (400hp) Td122f H2d 470932 3526008
Volvo F12 123e (400hp) Td122f H2d 478030 3526008
Volvo F12 123e (400hp) Td122f H2d 478122 3526008
Volvo F12 123e (400hp) Td122f H2d 478522 5333-970-6710
Volvo F12 123e (400hp) Td122f H2d 478673 312489
Volvo - D7 Hx40w 3978545 3592587 3592587-d
Volvo - D7 Hx40w 3978548 3592587
Volvo - D7 Hx40w 3978550 3592587
Volvo - D7 Hx40w 3978565 3592587
Volvo - D7 Hx40w 3978662 3539837
Volvo - D7 Hx40w 3978663 3592587
Volvo - D7 Hx40w 3978725 3592587
Volvo - D7 Hx40w 8113604 3592587
Volvo - D7a Wh1e 8112892 3535970 3535970
Volvo - D7a Wh1e 8192566 3535970
Volvo Bus D10a Hx40w 425703 3536545 4040718-d
Volvo Bus D10a Hx40w 425830 3539001
Volvo Bus Dh10a Hx40w 3979059 3580558
Volvo Bus Dh10a Hx40w 3979060 3593204
Volvo Bus D10a Hx40w 8113009 3536545
Volvo Bus Dh10a Hx40w 8113166 3595117
Volvo Bus Dh10a Hx40w 8113167 3590002
Volvo Bus D10a Hx40w 8113534 4027347
Volvo Bus D10a Hx40w 8113535 3593413
Volvo Bus Dh10a Hx40w 8194705 4027343
Volvo Bus D10a Hx40w 8194706 4027021
Volvo Bus D10a Hx40w - 3595118
Volvo Fl10 D10a Hx50 8194432 452174-0001 4031414
Volvo Fh12 (420-460hp) D12a Hx55 425720 3537840 3537840-d
Volvo Fh12 (420-460hp) D12c Hx55 1676089 3575079
Volvo Fh12 (420-460hp) D12a Hx55 1677098 3531858
Volvo Fh12 (420-460hp) D12a Hx55 1677725 3533544
Volvo Fh12 (420-460hp) D12c Hx55 1677726 3575237
Volvo Fh12 (420-460hp) D12c Hx55 3165219 4027013
Volvo Fh12 (420-460hp) D12a Hx55 8112637 3575237
Volvo Fh12 (420-460hp) D12c Hx55 8112921 3575237
Volvo Fh12 (420-460hp) D12c Hx55 8113407 3591077
Volvo Fh12 (420-460hp) D12c Hx55 8148873 452164-0001
Volvo Fh12 (420-460hp) D12c Hx55 20459353 3591077
Volvo Fh12 D12a Hx55 8113121 3538716 3538716-d
Volvo Fh12 D12a Hx55 8148987 3538718 3537840-d
Volvo F16 (520hp) Td162f H3b 866665 3530641 3530641
Volvo F16 (520hp) Td163es H3b 1556163 3530641
Volvo F16 (520hp) Td163es H3b 8112300 3530641
Volvo F16 Td162 H3b 1543496 3524789 3524789
Volvo Industrial Td160 H3b 849948 3524821
Volvo Fh16 D16a 470hp Hx60 1556916 3590055 3590054-d
Volvo Fh16 D16a 470hp Hx60 1556918 3590057 3590056-d
Volvo Fh16 D16a-td160 520hp Hx60w 1556919 3590059 3590058-d
Volvo Fh16 D16a-td160 520hp Hx60w 8112926 3590058
Volvo Fh16 (520hp) Td160 Hx60w 1556570 3533974 3590052-d
Volvo Fh16 (520hp) Td160 Hx60w 1556646 3534181
Volvo Fh16 (520hp) D16a Hx60w 1556917 3580589
Volvo Fh16 (520hp) Td160 Hx60w 8113193 3590052
Volvo Fh16 (520hp) Td160 Hx60w - 3532929
Volvo Fh16 (520hp) Td160 Hx60w - 3590053
hx40w Assembly number 4036378 16cm T3 inlet 60mm 7blade compressor 10blade turbine
Exhaust outlet is ID 83.5mm v-band OD 103.25mm
This turbo has an oddball compressor cover. It has an extended snout i guess youd call it with 2 threaded ports in it. When i got it it had what looked to be a temp sensor in one of them and the other was plugged off. There is no machined lip to help keep a hose on the inlet, but i dont think it would fall off either.
I cant verify the inducer size of the turbine because it is damaged, but the exducer is 64mm and holset said it was a 76mm inducer, so i beleive it should fit in the bep housing.
A piston must have came apart because there was aluminum chunks inside the housing. Trashed the inducer of the turbine
next to a evo3 16g
I will post specs on another hx40 when it arrives hopefully by the end of the week. It has a 18cm housing.
My billet 7 blade Compressor 60mm/85mm Holset HX-40 Came with a internally wastegated 16cm turbine housing. Numbers on the compressor cover look to be re-stamped.
Kit-3800400RX
Assy-3538221
Serial-1237540
This .pdf confirms that in 1999 the holset hx35 CHRAs (turbine wheels and compressor wheels) installed on the cummins diesel ram pickups changed. These later hx35s have been proven to flow 60lb/min. The 7 blade hx35 compressor debuted in 1999. . . Part numbers, OEM, cummins CHRA.
My 7 blade HX35w, confirmed 59lb/m flow (or more!)
TRANSMISSION/YEAR/ENGINE/ ORIGINAL PART NO./ CUMMINS PART NO./ HOLSET PART NO./ CHRA PART NO./ FRAME SIZE/ HSG. SIZE
MANUAL 2000 245 HP 3592767 3800799 3592766 4027212 HX35W 12 cm2
Found on all MANUAL 99-01 5.9 dodges.
I cannot identify my turbo... I have read thru all the posts and its not there. Heres a pic. It does not have an ID badge but it does have these numbers cast in the exhaust housing. 3523508 , 3524988, 1941050
Here is my HX40 didn't see these numbers posted kit 3802613RX, Assy 3532222, ser. M1319041. Its a 8 blade on the compressor, 12 blade on the exhaust and it looks like a 19cm. I will measure the wheel when I get my BEP in.
Can somebody please give me the part numbers for both 8 blade HX40 and HX35 turbos? With the billet wheel....
Thanks!
Here is the turbo I just bought. Anybody happen to know what this turbo came off of? I've looked through the various I.D. links and the .pdf files that are supposed to help with all of this, but no joy. Thanks.
1998-2003 cummins pickup. That's a 7blade hx35. I didn't look up the part numbers. But if theinducer is 56mm, then we know exactly what that turbo is: 60lb/min compressor. Can be pushed to over 37psi and still be on the map up to almost 55lb/min. 60lb/min at up to almost 30psi all still on the map. . . IF that has the 56mm inducer. The hx35 turbines all should be the same. 12cm^2 divided housings with the turbine wheel larger than a t31.
Not sure if this is a 56mm inducer, I took a few pics with my ruler, not very good but maybe someone can tell me if it is or not. Excuse the cell phone pics ha ha. On a side note, any tips for cleaning this thing?
Great thread with great info...thanks everyone! I'll add a little primer for measuring wheel diameter...
On the compressor wheel: Inducer = front of the blades (closest to the nut); Exducer = back of the blades (next to the center section)...it's opposite for the turbine wheel. Just want to make sure everybody knows where to measure.
On a turbo with an odd number of blades you need to measure the radius and double it, as there's no way to get an accurate 'ruler' measure of the diameter, since you don't have two physical points opposite one another across the full width. Measure from the tip of one blade to the center of the shaft, keeping the ruler 'flat' across the top of the shaft. Tilting the ruler will skew the reading a bit.
Thanks for that tip, it looks like a 56mm inducer. Right about 18mm from the edge of one blade to the tip and about 10mm from the center of the shaft to the beginning of the blade. Any ideas on making it nice and shiny? I was thinking PB and a scotch pad.
Ok my turbo has a few number i found some of the number but not all on the same page for the same turbo.
Assy. 3538218
Serial. 02349145
customer. 3800378-00-05/2
model. HX40W
and where it says holset on the compressor cover it says LM25S in smaller letters then HOLSET
on the Center section is says
HOLSET
3530521
I recently obtained what I believe to be an Holset HX40 Pro, except from all my reading I have not seen a combination like this one before.
Here is what i know, unfortunately the tag on the compressor housing is missing:
6 blade compressor wheel, 60mm inducer minor
12 blade turbine wheel
T3 tangential exhaust housing, and it says "14" in the casting, so I'm assuming a 14cm^2 housing.
Internally Gated
3.225" ID V-band outlet
Casting on turbine housing:
3533221
14 164 06
So the question, does anyone know how this T3 14cm^2 tangential exhaust housing preforms? I've heard the split T4 housings spool nicely and have great part throttle response, what about this smaller housing??
Pictures!
  • For sale 2g 2G FMIC Setup
    2G DSM FMIC Setup $375 + shipping & paypal feesDimensions * 29” end to end * 11” tall * 3”...
  • Wanted 2g 1995 eclipse gst ext trim above side skirt
    Looking for 1 exterior trim pieces.Passenger side: Door cap (long piece above side skirt)
    • athlete3344
  • Wanted 2g Gst or Gsx Eclipse
    Looking for a gst or gsx 2g eclipse
    • InclineDbPress
  • For sale 4G63 Sheet Metal Intake Manifold
    Sheet Metal Intake Manifold for 1G Cylinder Head $300 + shipping and paypal fees* for use with...
  • For sale 1g 1G Leather Steering Wheel
    1G Leather Steering Wheel $70 + shipping and paypal fees* I know a lot of guys cut the 1G hubs...
